Use the following procedure to add the common name of the Certificate Authority for the syslog server.
- Select System Log.
- Select the Certificate Table tab.
- Select Insert.
- In CaCommonName, type the common name of the Certificate Authority.
- Select Insert.
Certificate Table Field Descriptions
Use the data in the following table to use the Certificate Table
        tab.
        | Name | Description |
| CaCommonName | Specifies the Certificate Authority common name for a syslog server. |
